console.show();
const {
delivery,
interval,
quantity,
spec,
clickMode,
actionDelay
} = hamibot.env;
// 打印环境变量
toastLog('delivery = '+delivery);
toastLog('interval = '+interval);
toastLog('quantity = '+quantity);
toastLog('spec = '+spec);
toastLog('clickMode = '+clickMode);
toastLog('actionDelay = '+actionDelay);
// 创建悬浮窗并命名为 floatyWin
<vertical padding="16">
<button id="startBtn" text="开始任务" bg="#4CAF50" />
<button id="stopBtn" text="停止任务" bg="#F44336" enabled="false" />
<button id="moveBtn" text="移动脚本" bg="#607D8B" />
floatyWin.setAdjustEnabled(false);
floatyWin.setPosition(500, 100)
floatyWin.setSize(-2, -2);
var handlers = {
running: false,
taskInterval: null,
start: function () {
if (handlers.running) return;
handlers.running = true;
toastLog('任务开始了');
// 开始循环执行
handlers.taskInterval = setInterval(function () {
    toastLog('状态:运行中');
    var randomDelay = 5000 + Math.floor(Math.random() * 101);
    if (className("android.widget.TextView").text("确定").exists()) {
    // //         className("android.widget.TextView").text("确定").findOne().click();
        toastLog('点击了确定');
        clearInterval(handlers.taskInterval);
        if (className("android.widget.TextView").text("送到家").findOne().exists()){
            className("android.widget.TextView").text("送到家").findOne().click();
            sleep(randomDelay);
            toastLog('点击了送到家,等待'+randomDelay+'ms');
        if (className("android.widget.TextView").text("到店取").findOne().exists()){
            className("android.widget.TextView").text("到店取").findOne().click();
            sleep(randomDelay);
            toastLog('点击了到店取,等待'+randomDelay+'ms');
}, 1000); // 每秒执行一次
stop: function () {
if (!handlers.running) return;
handlers.running = false;
toastLog('任务停止');
floatyWin.startBtn.click(function () {
handlers.start();
ui.run(function () {
floatyWin.startBtn.enabled = false;
floatyWin.stopBtn.enabled = true;
floatyWin.stopBtn.click(function () {
handlers.stop();
floatyWin.startBtn.enabled = true;
floatyWin.stopBtn.enabled = false;
var movestatus=false;
floatyWin.moveBtn.click(function () {
if(!movestatus){
movestatus=true;
floatyWin.setAdjustEnabled(true);
}else{
movestatus=false;
// 保持悬浮窗不被系统回收
setInterval(function () {}, 1000); 执行循环的过程中 如果添加列className("android.widget.TextView").text("送到家").findOne()类似的查找,脚本会奔溃,如果是空跑 程序运行正常,解决该问题。
takkm3obas · 12 个月前
脚本在使用 className("android.widget.TextView").text("送到家").findOne() 进行控件查找时崩溃,通常是因为在某些情况下控件不存在或没有正确匹配,导致 findOne() 抛出异常。为了避免此类崩溃,应该在查找控件之前进行存在性检查。
以下是修复建议的代码:
var handlers = {
  running: false,
  taskInterval: null,
    toastLog('任务开始了');
    // 开始循环执行
        toastLog('状态:运行中');
        // 使用 exists() 检查控件是否存在
            toastLog('点击了确定');
            // 添加空值判断和 try-catch 避免崩溃
                let deliveryWidget = className("android.widget.TextView").text("送到家").findOne(1000); // 等待最多1秒
                if (deliveryWidget) {
                    deliveryWidget.click();
                    sleep(randomDelay);
                toastLog('送达家控件未找到或发生异常');
                let pickupWidget = className("android.widget.TextView").text("到店取").findOne(1000); // 等待最多1秒
                if (pickupWidget) {
                    pickupWidget.click();
                    sleep(randomDelay);
                toastLog('到店取控件未找到或发生异常');
    }, 1000); // 每秒执行一次
  stop: function () {
    toastLog('任务停止');
解释
  • 避免直接调用 findOne()
    • 使用 findOne(timeout) 并设置超时时间(如 1000 毫秒),以防止长时间阻塞。
    • 在获取控件后添加 if (widget) 判断,确保控件存在后再执行操作。
  • 添加 try-catch
    • 防止因控件未找到或其它异常导致脚本中断。
通过这些优化,即使控件不存在或查找失败,脚本也不会崩溃,而是继续下一轮循环。这样可以提升脚本的稳定性和健壮性。
