import uiautomator2 as u2
import time
import sys
from typing import Optional
class PostalAutomation:
def init(self):
self.d = u2.connect()
self.config = {
'base_delay': 0.02,
'critical_delay': 0.15,
'max_retry': 3,
'id_card_number': '130130199001071868',
'timeout': 2.0
self.setup_device()
def setup_device(self):
    """初始化设备设置"""
    self.d.implicitly_wait(self.config['timeout'])
    self.d.settings['operation_delay'] = (0, 0.5)
def safe_click(self, selector, retry: int = 3) -> bool:
    """安全的点击操作,带重试机制"""
    for attempt in range(retry):
        try:
            if selector.exists:
                selector.click()
                time.sleep(self.config['base_delay'])
                return True
            time.sleep(0.5)
        except Exception as e:
            print(f"点击失败 尝试 {attempt + 1}/{retry}: {str(e)}")
            time.sleep(1)
    return False
def safe_input(self, selector, text: str, retry: int = 3) -> bool:
    """安全的文本输入,带重试机制"""
        try:
            if selector.exists:
                selector.set_text(text)
                return True
            time.sleep(0.5)
            print(f"输入失败 尝试 {attempt + 1}/{retry}: {str(e)}")
            time.sleep(1)
    return False
def step1_select_customer(self) -> bool:
    """步骤1: 选择客户"""
    if (self.d(text="拼多多揽收").exists and
        self.d(text="拼多多退换货物品").exists):
        return self.safe_click(self.d(text="客户"))
    return False
def step2_input_code(self) -> bool:
    """步骤2: 输入客户代码"""
    if self.d(text="常用客户").exists:
        return self.safe_input(
            self.d(resourceId="cn.chinapost.jdpt.pda.pickup:id/post_code"),
            "pddth"
    return False
def step3_select_client(self) -> bool:
    """步骤3: 选择客户"""
    if self.d(text="PDDTH").exists:
            self.d(textContains="上海寻梦")
    return False
def step4_open_menu(self) -> bool:
    """步骤4: 打开菜单"""
    if self.d(text="未实名").exists:
            self.d(resourceId="cn.chinapost.jdpt.pda.pickup:id/iv_main_menu")
    return False
def step5_select_verify(self) -> bool:
    """步骤5: 选择实名校验"""
    if self.d(text="实名校验").exists:
            self.d(text="实名校验")
    return False
def step6_manual_input(self) -> bool:
    """步骤6: 手工输入"""
    if self.d(text="重置/手工输入").exists:
    return False
def step7_input_id(self) -> bool:
    """步骤7: 输入身份证号"""
    id_input = self.d(resourceId="cn.chinapost.jdpt.pda.pickup:id/et_id")
    return self.safe_input(id_input, self.config['id_card_number'])
def step8_submit_verify(self) -> bool:
    """步骤8: 提交认证"""
    if self.d(resourceId="cn.chinapost.jdpt.pda.pickup:id/et_id").exists:
            self.d(text="人脸校验/确定")
    return False
def step9_complete_post(self) -> bool:
    """步骤9: 完成收寄"""
    if self.d(text="已实名").exists:
            self.d(text="收寄")
    return False
def step10_go_back(self) -> bool:
    """步骤10: 返回"""
    if self.d(text="打印面单").exists:
        self.d.press("back")
        return True
    return False
def step11_return_home(self) -> bool:
    """步骤11: 返回主界面"""
    if self.d(text="国内揽收").exists:
            self.d(resourceId="cn.chinapost.jdpt.pda.pickup:id/pet_post")
    return False
def run(self):
    """执行自动化流程"""
    while True:
        try:
            steps = [
                self.step1_select_customer,
                self.step2_input_code,
                self.step3_select_client,
                self.step4_open_menu,
                self.step5_select_verify,
                self.step6_manual_input,
                self.step7_input_id,
                self.step8_submit_verify,
                self.step9_complete_post,
                self.step10_go_back,
                self.step11_return_home
            for step in steps:
                if not step():
                    print(f"步骤 {step.__name__} 执行失败")
                    break
            time.sleep(0.5)
HAMI_4657853242 · 5 个月前
你提供的代码是使用uiautomator2库的Python脚本,而Hamibot使用的是JavaScript引擎(Rhino 1.7.15),两者API完全不兼容。Hamibot有自己的UI自动化框架,需要使用JavaScript编写脚本。
以下是针对邮政自动化流程的Hamibot实现方式和关键差异说明:
Hamibot脚本实现要点
// 邮政自动化脚本(Hamibot版)
function postalAutomation() {
    // 步骤1: 选择客户
    function step1_selectCustomer() {
        if (text("拼多多揽收").exists() && text("拼多多退换货物品").exists()) {
            return text("客户").findOne().click();
        return false;
    // 步骤2: 输入客户代码
    function step2_inputCode() {
        if (text("常用客户").exists()) {
            return id("cn.chinapost.jdpt.pda.pickup:id/post_code")
                .findOne()
                .setText("pddth");
        return false;
    // 步骤3: 选择客户
    function step3_selectClient() {
        if (text("PDDTH").exists()) {
            return textContains("上海寻梦").findOne().click();
        return false;
    // 步骤4: 打开菜单
    function step4_openMenu() {
        if (text("未实名").exists()) {
            return id("cn.chinapost.jdpt.pda.pickup:id/iv_main_menu")
                .findOne()
                .click();
        return false;
    // 其他步骤类似实现...
    // 执行流程
    var steps = [
        step1_selectCustomer,
        step2_inputCode,
        step3_selectClient,
        step4_openMenu
        // 添加其他步骤函数
    for (var i = 0; i < steps.length; i++) {
        var result = steps[i]();
        if (!result) {
            console.error("步骤执行失败:", steps[i].name);
            return false;
        sleep(200); // 等待操作完成
    return true;
// 启动脚本
launchApp("cn.chinapost.jdpt.pda.pickup");
postalAutomation();
关键差异说明
  1. 选择器语法不同:
    • uiautomator2: d(text="客户")
    • Hamibot: text("客户").findOne()
  2. 控件操作方式:
    • Hamibot使用链式调用:text("客户").click()
    • 对于输入框:id("input_field").setText("内容")
    • 知识库中提到:setText()用于设置文本框内容,input()用于追加内容
  3. 等待机制:
    • Hamibot推荐使用findOne()自动等待控件出现
    • 示例:id('action_log').findOne(6000) 在6秒内查找日志图标
  4. 返回键操作:
    • Hamibot使用back()函数,而不是d.press("back")
  5. 超时处理:
    • Hamibot的findOne(timeout)可以设置超时时间
    • 如:id('submit_button').findOne(3000)
优化建议
  1. 添加适当的等待时间:sleep(200)确保界面稳定
  2. 使用waitFor()确保关键控件出现
  3. 对于关键操作添加重试机制:
    function safeClick(selector, retries) {
        for (var i = 0; i < retries; i++) {
                selector.click();
                return true;
                sleep(500);
        return false;
  4. 针对邮政应用的特殊控件,可以使用知识库中提到的组合条件定位:
    className("android.widget.EditText").depth(10).findOne().setText("pddth");
如果你需要特定邮政应用界面的详细选择器定位方法,可以提供具体界面截图或控件信息,我可以给出更精确的选择器方案。
